Wheels Pic thread - Ive made a start
specks
Re: Wheels Pic thread - Ive made a start
Post by specks »
I'll text Adil to confirm how the Volvo wheels are fitted.
specks
Post by specks »
No spacers,adaptors,nothing just straight swap.
Turbodave
Post by Turbodave »
C70, S70R or V70R and yes, 5 x 108 so not sure how he got away with using standard bolts give the Turbo is 5 x 110?
RAF Engineering?
Choose Cavaliers, choose Air Max, choose Tom Wilson and Ultrasonic, choose V-power, choose 6th gear, choose Toyo Proxes, choose to prove anything is possible... except stopping the back arches rusting.
www.cavalierturbo.com www.wallaceperformance.co.uk
2mm is noithing really
like fitting fait wheels on a vaux
fiat......4x98
vaux .....4x100
straight on
specks
Post by specks »
No idea Dave but that's what his text said
Stoater85
Post by Stoater85 »
gsi pie wrote:2mm is noithing really
fiat......4x98
vaux .....4x100
straight on
Yea. I had fiat wheels on my last cav, and my team dynamics on this cav are ford fitment! 2mm is nothing.
dave955
Post by dave955 »
I'd say 2mm is a lot when there meant to fit exact. I'd personally run wobble bolts
Turbo #2 found itself sat on the Astra's wheels a few weeks back. 17-inch SE2's from my Mk4 Linea Rossa. Apart from the fact that both car and wheels were filthy I quite liked them. The Astra, however, looked shite on the Cav rims.
Turbodave
Post by Turbodave »
fiat......4x98
vaux .....4x100
straight on
I dunno...
The bolt hole is angled as are the bolts, so therefore when you tighten them down fully the bolts are seated in the bolt holes with equal pressure/force/whatever all the way round. If you have bolts going into a hole that's 2mm out then the force will be concentrated to one side of the bolt hole rather than equally and in this case where the Volvo's bolts are in a 108mm diameter pattern and the Cavalier is 110mm, the force of the tightened down bolts will be on the outer edges of the bolt holes rather than centred as it should...
I'm not convinced at all, especially when you consider the bolts are tightened down to 110 - 120Nm and that's a shit load of force and on a wheels with the wrong PCS, that's a shit load of force where a shitload of force isn't meant to be, bearing in mind the angled faces/bolts will also exaggerate said force so in effect when you tighten the five bolts down, they'll in effect be trying to remain on a 110mm diameter pattern where the wheel is 108mm...
It's basic engineering and it's not right!
John Owens
Post by John Owens »
Some excellent photos of some very smart cavs on this thread . Good work guys :-)
Barney
Post by Barney »
Can anyone photoshop a set of Lenso BSX 17's or 18's onto a satin red cav please as im considering fitting some but cant picture it my head, head seen them fitted to other colour cars and they look good.
Ta..
dave955
Post by dave955 »
If your fitting bsx alloys beware you will be doing major archwork
Cav.turbo
Post by Cav.turbo »
ET 35 momo arrows 60+ plus drop
ET 35 does fit :)
dave955
Post by dave955 »
Looks mega on those
John Owens
I had et 35 borbetts on my gsi when it was lowered 60mm & they scrubbed like fook ! Your lucky Si :-)
Sim Dhillon
Post by Sim Dhillon »
Omega alloys
Sim Dhillon
Porsche
belmont_dazz
Post by belmont_dazz »
What size are the porsche wheels? Are they the same pcd do you know?
porsche wheels are 5x130
GSi on 16" BBS Calibra DTM Wheels
joe cavalier sri
Post by joe cavalier sri »
16 tsw stealths
uncle_sam
Post by uncle_sam »
An another style, german style , borbet A in 7.5j ET25, one pic of my car.
Matemos a sus mujeres y violemos a su ganado, eso les confundira.
ive always liked them :)
OFront wheel looks like it is too close to the door. I would recommend that you check the wishbone as it is probably bent, although it could be the angle of the photo?
