stud n nut conversion
has any one fitted the nut n stud conversion onto their cav or any other car?
i fancy a change n something diff from the normal bolt
cheers
cheers
Re: stud n nut conversion
How about cheese? Much simpler to execute.gsi pie wrote: i fancy a change n something diff from the normal bolt
Apart from the fact that it makes it easier to line up when fitting the wheel I can't really see any point to it?
i see were you coming from fella
if i stud conversion it i get a nice choice off nuts for the car then
im fussy lol
im fussy lol
Nice choice of bolts not enough?
i got red anodized ones atm
been looking at tuner allen nuts etc
plus 18s are a bugger to keep on the hub when trying to put bolts in etc
Yeah it's easy I'd fit them with some permanent threadlock but other than that no issue
That's fair enough. It's not something I've seen done before but I guess it would depend a lot on what studs are available. With the hubs not being machined for studs the holes would probably need a shouldered stud.
so wind in and thread lock (not cheap stuff)
some thing to do this week then
Id perm threalock it rather than standard stuff as you dont want wind it out when your undoing it.gsi pie wrote:so wind in and thread lock (not cheap stuff)
LOCTITE 648 is what id use.
Ive never had a standard wheel bolt or nut round off on me, the allen key bolts on the other hand...
I understand where your coming from, the slightest touches can enhance a cars appearance, especially attention to detail, but I wouldnt like to tempt fate.
