Super touring tyre conundrum
Just got my powder coated supertouring alloys shod with new rubber, not having much of a clue about tyre size for the V6 I went with the fitters suggestion based on the Vectra B (as that is what the alloys originally came off). But once at home, standing new wheel next to the car I see it is way too big, so after some online looking I want other peoples confirmation/recommendation.
The cav currently has steelies of 195/60/15, so I think I should now ask for 205/45/16.
Re: Super touring tyre conundrum
The tyres I had fitted were 205/55/16. Not sure whether this will give me enough travel on the Eibach springs/shocks.
bigmitch
Post by bigmitch »
I checked online the radius dropped about 8 cm form the 195/60/15 to 205/45/16 so should help plus lower the car as well
I think cavs with smaller dimater tyres than standard look strange. As they dont seam to fill the arches.
Tha cav turbo came with 205/50/16 so I'd go for that.
I know that the 205/40/17 I have on mine are too small compared to the original 195/60/15.
So my next set are going to be 205/45/17 which have identical rooling radius to the originals.
They help fill the gap in the arches better and also gives a little extra air for comfort.
Plus i'm annoyed with the alloy wheel centre I bought my wheels for my toyota in a few years back. They told me I neede 215/40/17, but they are tiny compared to the original 205/55/17. So I'm going to get a new set now.
When you go wider with a tyre you are supposed to go to a lower profile on the same size rim, my motorsport has 195 60 15 & the gsi has 205 55 15's. I believe it's the same for rim diamter, I think 215 50 16's would give you the right rolling resistance to keep your speedo right.
bigmitch
Post by bigmitch »
HAIRIBO wrote:I think cavs with smaller dimater tyres than standard look strange. As they dont seam to fill the arches.
Should try 215/40/17 that will fill the arch .I had them on last cav gsi but that depends if have a bad back or you want one ?
Decided to go ahead and fit one of the alloys on the front - at 205/55/16 they *just* fit with barely an inch top room. Looking online, a drop to 205/50/16 would give me a little more room and it's the size Hairibo also suggested.
I don't want rubber band style and I do have a bad back so looking for a happy medium. I may swallow my pride and take them back tomorrow.
bigmitch
Post by bigmitch »
lowrider dave wrote:Decided to go ahead and fit one of the alloys on the front - at 205/55/16 they *just* fit with barely an inch top room. Looking online, a drop to 205/50/16 would give me a little more room and it's the size Hairibo also suggested.
Good move low profiles and cavs don' that what riuned my last cav gsi looked good though
DiplomaXE
Post by DiplomaXE »
as they are wider than turbo rims etc, vectra sized 205/55's will hit the front arch lip/liner if you are lowered dave. also 55's on the back picked up on the very front lower part of the rear arch when i had a rear passenger. you need 50 series turbo sized like i started with, or some 45 profile, like i usually run. have all sizes here if you want a lend of one to check.
Cheer Pete, would appreciate trying a 50 or even a 45 to see what the clearance is like - the tyre place told me to come back with the V6 and they'd do the same (see which tyre suited) but as it'll be 2 weeks before I get a valid MOT that's not going to happen anytime soon. Drop me a line and we'll work something out?
