Cavalier342 wrote:Given the two manufacturers, I stick with Vauxhalls thanks.
Me too now.
Although some folk say "an engine is the same no matter what the car" I'm finding it difficult to work with the cavalier as it's a lot more advanced
That's sort of true in some ways. However before owning my first C18NZ auto hatchback I knew next to nothing about motors. Cavaliers taught me about working on engines. Never worked on a diesel though.
Previous: China Blue 1989 Vauxhall Cavalier L 18SV Kings Blue 1992 Vauxhall Cavalier LSi Auto C18NZ
Cavalier342 wrote:That's sort of true in some ways. However before owning my first C18NZ auto hatchback I knew next to nothing about motors. Cavaliers taught me about working on engines. Never worked on a diesel though.
I haven't to be honest.
My first diesel was the mk2 I owned for 6 months before I bought the cavalier.
Unfortunately I have arthritis in most of my joints and especially my hands so I can't use tools now so I rely on friends to do the hard work.
The diesel cavalier if running ok, Can be very easily tuned you can up the power to around 100bhp and still be 'safe' and reliable. Also run very well on veg oil which atm is around £13 for 20L
Super89 wrote:The diesel cavalier if running ok, Can be very easily tuned you can up the power to around 100bhp and still be 'safe' and reliable. Also run very well on veg oil which atm is around £13 for 20L
It's running really well to be fair but lacks boost.
Apart from that the engine runs sweet.
If I can get it right I'll think about tuning it
You need to plug in a boost gauge and see what pressure its running at, STD i think they should run around 0.7 bar. Have you checked both air boxes, Only the one on top of the engine should have the air filter in. Also the inlet gasket will need doing i bet. Most do by now.
Super89 wrote:You need to plug in a boost gauge and see what pressure its running at, STD i think they should run around 0.7 bar. Have you checked both air boxes, Only the one on top of the engine should have the air filter in. Also the inlet gasket will need doing i bet. Most do by now.
As above check the air box in left corner of of the engine bay I found a very dirty old air filter in mine which was restricting the air flow. Also with these Isuzu engines the turbo doesn't kick in until 2500 rpm, until then its pretty flat.
Bob Dodds wrote:As above check the air box in left corner of of the engine bay I found a very dirty old air filter in mine which was restricting the air flow. Also with these Isuzu engines the turbo doesn't kick in until 2500 rpm, until then its pretty flat.
I don't think my turbo is kicking in at all. If it is its not working properly
Quick update :
I took it for a blast up the M6 last night and although it's not perfect it seems to be running a bit better.
I have noticed that it seems to be lacking in power when cold and is better when it gets up to normal running temperature (about 90 degrees)
I still think that the turbo is really weak and /or not working at all though as when I have my foot flat to the floor it still struggles to accelerate
That sounds like a blown turbo to me. If I'm right in thinking, if the turbo is nackered, then you won't only lose boost from it, but the ECU will also try to re-compensate for the lack of air being drawn in, therefore losing even more power. Hence why it is so sluggish as you describe. I'm far from a diesel expert but you learn things over the years.
Cavalier342 wrote:That sounds like a blown turbo to me.
I was thinking the same to be honest.
I've got my mechanic coming out on Friday to do some work on it so I'll get him to check it out.
How easy is it to source a replacement turbo ?
