bought second hand gearbox how a find owt if it wud fit
Ritchie
Post by Ritchie »
[b]m[/b]bought a second hand gearbox from a breckers i hnk its a f10 its from a 1.4 8 valve need a f13 for a 1.6 8valve the in put shaft is longer on the f13 than on the beilevf to be f10 wud ths gearbox fit need help realli stuck
Re: bought second hand gearbox how a find owt if it wud fit
do mean the f10 for a smooth bit after the splines?
Ritchie
Post by Ritchie »
The f10 hasnt got the smooth bt the f13 has the smooth bit
F10
F10
it will fit
what engine is it going on??
the new box should be stamped tho fella
Ritchie
Post by Ritchie »
The weird hng is the aint no stamp a cleand the box and nuffin and it wul b goin intn a 1.6 8 valve
i use a f13cr of my c16se engine
what engine did it come off?
Ritchie
Post by Ritchie »
1.4 8 valve a hnk its a f10 gearbox coz therz nae stamp nt sure
Ritchie
Post by Ritchie »
Is there anywerd else a cud tell wat box it is
there will be a number here:
you need to scrub it realy hard to see the numbers
which will be the final ratio will tell you if its a good short ratio revy box or a long ratio box
like this :
If there is no obvious marking at the top near the turret then look very carefully around the edge of the endplate, there is a flat section which has the id numbers stamped on it in letters about 6mm high. I don't think there would be an issue fitting the box, most vauxhall boxes are fairly interchangeable with the right clutch and flywheel, but if it is an f10 I wouldn't bother as the bearings are crap on them anyway. You'd be better sourcing an f13.
Ritchie
Post by Ritchie »
The f16 w418 f10 w418 am gawny get it changed tommora x
f16 wont fit a 1.6 8valve cav wiil it?
f16 is a big block gearbox for 2.0 cavs iirc
Ritchie
Post by Ritchie »
Ment f13 w418
aww right :lol:
wide ratio box will be good for motorway drving etc :)
Ritchie
Post by Ritchie »
Jst another quick question wer wud a get fuel lines frm for my cavi 1.6 8v ls injection 1993
pop to local motor factors theyl sell copper pipe buddy :thumb
93 1.6 8v is almost certainly a c16nz2 which is the large block engine
Ritchie
Post by Ritchie »
Hnkn mines c16nz
Ritchie
Post by Ritchie »
Got a f13 gearbox now but hasn't got an inspection plate oan the gearbox and the casing looks a bit different and the input shaft is shorter on the replacement will this gearbox work the same as the old
I have always found the code on top.. as Planetc describes.
It was on top on my 1.3 Cavalier Mk2 fitted with an F10.
This is a library picture clearly identifying an F20
box code.jpg (37.85 KiB) Viewed 1425 times
I shall check the 1.6's available in 1993 shortly.
Okay UPDATE
1.6's available in 1993 according to TIS were
16SV and
C16NZ2
No mention of the C16NZ.
Ritchie
Post by Ritchie »
It's defo a f 13 coz there is a number that matcha the two boxes but the hong that's puzzling me is the shaft being shorter. That the onli thing puzzling
From that, I assume you mean the input shaft.
So we are comparing shafts from two F13's or an F10 and an F13?
If it is an F10 and an F13, then it could be down to flywheel thickness and clutch plate size.
The F10 may have a different set up, and so doesn't need the shaft to be as long
If they are both F13's
Hmm, I wonder if the car has had a clutch change, (the car the gearbox came from)
and the owner / garage hadn't pushed the input shaft fully into the box, and fitted the retaining circlip.?
Although 5 speed boxes are usually tight on the input shaft, the circlip is there for a reason - to stop the shaft from creaping out over time.
Just a thought...
Maybe one has a sliding shaft and one is later fixed shaft?
Ritchie
Post by Ritchie »
The input shaft on the gearbox a had in has a none splind bit at the end the replacenent dosent
