Removing the EGR valve from the C18NZ engine
This is removing the EGR valve from my Cav,
Re: Removing the EGR valve from the C18NZ engine
I do want a blanking plate for mine, always forget it though. Does it improve things in your case?
Gazza 1701a was the person who suggested it and he has found it to be a small improvement. Having driven his car it does seem to pick up better.
gazza1701-a
Post by gazza1701-a »
Shame you can't road test it now.....Nice pics BTW :thumb
For once i thought i would take pictures as i did it.
Does anyone know what else you need to remove & or blank off ? Specifically the pipe that goes to the bulk head & disappears under the scuttle cover into a flying saucer shaped thing then changes pipe colour & carries on into under the drivers side wing ?
Leave that pipe to the carbon cannister alone. That should still stay connected to the throttle body to deal with fuel vapour.
To do the EGR,
All you need is..
1 - fabricate a steel blanking plate.
2 - get an EGR valve gasket. (Or a piece of cereal packet / cardboard document folder)
3 - plug the pipe that goes between the throttle body and the EGR valve.
That's it.
