gsi misfire
cavaliersri
gsi misfire
Post by cavaliersri »
hi
can anyone help me please.iv just bought a gsi 4x4.it idles fine bit misfires under load.the car was garaged for 6 years until recently
iv changed the plugs but this didnt help
its a 2 lirte redtop sfi
please help.its pisxing me off now
thanks
if the bumpers dont scuff then it aint low enuf.
Re: gsi misfire
aint this one your selling?
hamishvaux
Re: gsi misfire
Post by hamishvaux »
What have you tried?
Current fleet
Cavalier gsi 2000
Nova saloon 2 door
Re: gsi misfire
Have you tryed the dis. cap, rotor arm, coil, plug leads and dose the early xe have an igintion amp module?
cavaliersri
Re: gsi misfire
yeah am selling it but needs to run right.iv only tried plugs so far.im gona try leads/cap/rotor arm tomoro.just wondered if u guys thought it might be something else.im not too clued up on the redtop engine.lol
hamishvaux
Re: gsi misfire
I would try those first. Bang some fresh fuel in if its stood so long aswell.
Current fleet
Cavalier gsi 2000
Nova saloon 2 door
cavaliersri
Re: gsi misfire
hi.just another quick update.iv just changed the dizzy cap/leads/rotor arm also stuck £20 of fuel in and still no joy.still missing under load.do you think a fuel filter is in order as car sat for 6 years.it idles fine and drives.its only when you put the foot down thai is misses.can it be a cam shaft sensor.any help would be greatly appreciated.
Re: gsi misfire
could be fuel presure reg
check TPS
cavaliersri
Re: gsi misfire
sorry,i meant crankshaft sensor.lol
cavaliersri
Re: gsi misfire
what does tps mean?
cavaliersri
Re: gsi misfire
thank god i have u guys to ask questions to.lol.am i right in thinking that the fuel filter/pump is located on the n/s/r of the car next to the chassis leg.
Re: gsi misfire
fuel pump ser up is driver side rear
remover rear wheel and youl see it :thumb
tps = throttle position senor on throttle bodie under sfi box
cavaliersri
Re: gsi misfire
thanks for the help ill go have a look.my mates gona drop me off a crank sensor and tps later so will try them too.
Re: gsi misfire
take note when you remove tps as it just dont bolt on
it can be adusted etc
Re: gsi misfire
Also make sure that the plug for the maf is not poking up in the air and is well tucked down ( loosen the hoseclips and twist the pipe). If they are sticking up then they can rub on the underside of the bonnet and upset it when you are under load.
cavaliersri
Re: gsi misfire
thanks.ill have a look at that later.but too cold outside for fixing cars.lol
dingdongbells
Re: gsi misfire
Post by dingdongbells »
i had a prob like this in one of my old gsi's
idled perfect and drove prefect
but when i went to get it to her she missed
i tryed everything
it turned out the fuel line from the pump and worn away and was leaking but it was very had to find it,
Re: gsi misfire
mine was a knackered Fuel pressure regulator and injector, changed the fuel rail and its perfect
cavaliersri
Re: gsi misfire
hey folks thats
plugs
leads
rotor arm
dizzy cap
engine temp sens
crank sens
fuel filter
tps
all been changed.it seems to miss more when it warms up.
where do i go next.
i think the oil cooler mite be leaking oil into the water.would this cause a misfire?
Re: gsi misfire
Its impossible for the oil cooler to leak oil in the water as it doesnt have water in it.
Have you tried another afm? Tried unplugging the lambda
cavaliersri
Re: gsi misfire
it dont think it has a lambda as i couldnt find it.iv just had a afm dropped off so im gona try that tomoro.
cavaliersri
Re: gsi misfire
sorry.yeah it does have a lambda.i just found it.lol
cavaliersri
Re: gsi misfire
hey.just like to say a big thank you to everyone for answering my questions but i have another one for you.iv noticed my car doesnt have a catalyst.can anyone tell me the month/year that you need a cat.mine is a 1992 on a k.thanks for your help i really appreciate it.
Re: gsi misfire
I might be wrong, but I seem to recall all k plate cars required that cat tests. Basically Aug 92 onwards. Have you sorted the misfire now?
Re: gsi misfire
I've heard that it became compulsory in 94 dunno If this is true
