MORE QUESTIONS - Engine SWAP
Barney
Post by Barney »
Hey,
Can someone tell me is this the correct SAAB engine ie B204 to go into a Cav GSI 4X4.
Thanks
Re: MORE QUESTIONS - Engine SWAP
From this http://en.wikipedia.org/wiki/Saab_H_engine
Id say it was a B205 OR B235
The B205 and B235 engines are an evolution of the B204 and B234 engines. They were introduced in the 1998 Saab 9-5 giving reduced fuel consumption and emissions with improved refinement. The changes included lightweight internal components (lighter valves, softer valve springs, longer conrods with lighter pistons, and balance shafts), lighter block and cover, heavier flywheel and more. Another development was the introduction of the Trionic 7 torque demand type engine management system. Trionic 7 equipped engines have the black direct ignition casing on top of the engine rather than the red of the Trionic 5.
I may be wrong
Barney
Post by Barney »
Gaz wrote:From this http://en.wikipedia.org/wiki/Saab_H_engine
I may be wrong
Cheers Gaz :thumb
But million dollar question is will it fit and is it worth it???
5853moore
Post by 5853moore »
The b204 you want will have a red/black engine cover. Not the all black one. That looks like the later low blow engine.
Barney
Post by Barney »
So this one yeah
5853moore
Post by 5853moore »
That looks like it but i would get it double checked!
Red injection cassette cover above is the B204.
