20xe coolant hose diagram it's for a cavalier gsi2000
Posted: Mon Jun 03, 2013 10:01 am
by Chally2012
Hi need some help me and my brother in law have rebuilt the gsi 2000 cars running sort of fine apart from the over heating issues.the engine gets temp goes into the red but water in the radiater is cold its a new radiater I had swapped the black plastic coolant pipe at the back of the inlet manifold or an updated one the metal one from tx auto sport but have swapped it bk for the plastic one does any one think it could be an air lock that I have and also how do I get it out as also what's strange is the over heating fan isn't kicking in at all fan works fuses ok and put new rad switch and thermostat in but as I say coolant in rad is cold which I suspect why fan switch may not be activating fan as temp cold in rad any ideas really much apreciated.
Re: 20xe coolant hose diagram it's for a cavalier gsi2000
Posted: Mon Jun 03, 2013 5:03 pm
by planetc
Is the water pump actually pumping?
Posted: Mon Jun 03, 2013 8:44 pm
by Chally2012
Hi thanks for responding yeah it's a new original part hat I put on strange thing is hot water in coolant tank but cold to Luke warm in rad is it possible for an air lock plus if the return is pumping water bk in to coolant tank how wold u know if water pump is not working?thanks
Posted: Mon Jun 03, 2013 9:42 pm
by John Owens
Did you check the thermostat worked before fitting ?
Posted: Mon Jun 03, 2013 10:01 pm
by planetc
Pull a hose off and start it up, if the pump is working it'll chuck water everywhere. Airlock are not a problem, and the only people I have ever seen that suffered with them have later replaced the head gasket. Check the pump and the stat, and reverse flush the Rad in case it's blocked and then see where you are.
Posted: Tue Jun 04, 2013 8:30 pm
by Ads
just because you changed the pump dosnt mean its ok, i went through temp issus with my cav turbo, tried all sorts to cure it, eventualy took out the brand new pump i had fitted earlier and the impellor just fell off, thus i had no water circulation, Ads
Posted: Tue Jun 04, 2013 8:55 pm
by Ads
Ads wrote:just because you changed the pump dosnt mean its ok, i went through temp issus with my cav turbo, tried all sorts to cure it, eventualy took out the brand new pump i had fitted earlier and the impellor just fell off, thus i had no water circulation, Ads
Posted: Thu Jun 06, 2013 9:40 am
by Chally2012
Thanks for that lads yeah 2nd thermostat now and will try theses things you mentioned.ads that's mad about the water pump and that was a brand new one?
