Converting 2WD to 4WD
Coppen
Post by Coppen »
Is it possible without using the entire rear floor pan? Is the tunnel suitable on a 2wd car to accept the prop?
Have i missed anything off the list of that is required to convert a 2WD to 4WD?
Prop
Rear Sub/Diff
TX box
I've a mint 48k 2WD V6 CDX that i'm pondering converting to 4WD and just need a bit of guidance.
Is it possible to just modify/cut/weld the pan where the subframe will mount? Or does it mount in the same place on a 2WD????
Re: Converting 2WD to 4WD
Whole floorpan is different. Conversion isnt econmically viable time effort etc.
The tunnel on a 2wd gsi isnt suitable for 4wd etc its just too much effort for little gain
Anything can be done with time and deep pockets. The v6 block may not give room for a transfer box exhaust is also in way
Coppen
Post by Coppen »
Yeah i thought that would be the case.
Don't really want to chop it seeing as its that mint.
I'll stick to the Saab/F28/2WD conversion instead :)
cheers guys
SteLowis
Post by SteLowis »
Don't the 2wd have rear beam as well?
