C20xe cold start problem
eco.tec.warrior
Post by eco.tec.warrior »
Went to start the cavalier today and won't start at all it's turning over and getting fuel but won't start
Any ideas it's coil pack engine
eco.tec.warrior
Re: C20xe cold start problem
Any ideas
Check the electrical plugs around the engine bay. Long shot but it could be that one has become loose.
I know on the 8 valve engines, it's common for the crank sensor plug to disintegrate where it's too close to the engine. Plastic just falls apart over time. Has the engine got wet at all? Could try water repellent spray around the coil pack, electrics etc.
cts and or cts wiring, is the ecu light flashing?>
eco.tec.warrior
Folks found the problem it's crank sensor. Are they easy fit
One 10mm bolt. Just make a mental note of where the wire runs as it runs behind the engine mount
eco.tec.warrior
Does the power steering bracket have to come off seems be in the way a bit
No, it'll come out round it
