Wierd whining noise after R turn from cold.
For a while now my 1.4 has been producing what sounds like a gear whine after swinging right about 200yds from home. It's a thin, edgy whine which disappears inside a half mile. In over 40 years of driving I've never experienced anything like it. The only idea I've had is that one of the D/S plunger joints has dried out grease in it and this is temporarily preventing the D/S returning to its correct free length and is side loading the diff bearing(s). Has anyone else had such a phenomenon?
Re: Wierd whining noise after R turn from cold.
Yes, that's the first thing I checked. Thanks.Gaz wrote:Enough gearbox oil
Is there enough grease in the CV joints?
That I don't know but I know I'll enjoy checking! It's possible that they have 24 year-old grease in them as the car has done only 35000 miles.Cavalier342 wrote:Is there enough grease in the CV joints?
CV joints don't usually whine, they knock or seize. Difficult to suggest things without hearing it but based on the description I would favour a diff problem myself.
Oh and a seizing joint will also give feedback as vibration.
I thought CV as the previous owner of my V6 said she kept hearing a sqealing noise coming from the front end, before I bought it, I popped the nearside CV boot off to find next to nothing in grease in there... Chucked more in and haven't heard anything since. Worth a check just in case even if it's not that.
Possible it hasn't quite reached seizing so you could be right.
Talking of whining my misses wants tea and a slice of cake
