rev limiter....20xe
rev limiter....20xe
right here's a strange one for you all :lol:
driving my white cav tonight , was giving it some love (revving lol ) and I seem to have lost my limiter now :lol: ???
I did have one last night tho :lol:
it revs straight thro 8 like its on carbs??
it runs a groupe N ecu but that's been fitted since ive had it
how are the limiters controlled on these? ECU or dizzy?
any help would be great as don't fancy my conrods goin east :lol: :lol:
Re: rev limiter....20xe
ecu, mine has eds chips and it has the 8k limit.
mined use ti limit at 7.8k iirc
proper group N ecu with paper work to
so could be any ecu error /fault ya gaz?
I didn't know EDS done stuff for the XE's only LET's I thought
Cant see it being anything else. planetc will probably correct me
Yea they dont do a lot tbh, i did see a small improvement but id have been pissed if it had been the £300 eds wanted
http://www.eds-motorsport.de/shop/de/Op ... steigerung
I can't really see it being much else either, if the limit is set in the ecu then the only way it could fail is if the ecu doesn't know the engine speed, which would lead to other problems. Rather odd really?
Maybe your rev counter needle has slipped?
rev counter is fine as it idles fine
there is just no limiter lol
hold you foot flat and it just revs and don't stop the sound is really nasty lol
just went out and wipped the ecu out
and mr chip want to leave its holder ffs :wall
can I just push the chip back in??
I don't want to fuk anything up?
thanks :thumb
yea but might be worth pulling it fully out you dont want it going in pissed.
ok
is it just the 6 screws holding it together gaz?
last thing I want it to bugger the board up :lol:
thanks
Its the plastic pin in the middle needs the centre pulling out and unclipping the pegs on the edges
