Saab 93 Turbo
ashs_cav
Saab 93 Turbo
Post by ashs_cav »
Just found out my Grandad had a W'Reg Saab 93 Turbo and the gearbox is nakered aparently..
Wanting to know will this go into my Cav..ino you may not be able to tell without seeing it but just thought id ask
Ino the b204 Saab engine or sonething along those lines goes in , but unsure on this..if it does....
Soon be a Caab SRI Turbo :)
Re: Saab 93 Turbo
93 should be cav/vectra based so probably, chip pan dan should be able to have an idea
Chip Pan Dan
Re: Saab 93 Turbo
Post by Chip Pan Dan »
can you post a pic of the bay up?
if its a b204 it should have the red coil pack other models have black ones
ashs_cav
Re: Saab 93 Turbo
Post by ashs_cav »
Do the black ones fit?
And what bhp do they run..
Seen on internet some are 154 some 185..some 200
154 is abit disappointing
Chip Pan Dan
Re: Saab 93 Turbo
they do fit, but there not as powerful and easy to tune
ashs_cav
Re: Saab 93 Turbo
Post by ashs_cav »
Do the full front legs fit the cav hatch? Aoarnelty the rear axle does :S?
Chip Pan Dan
Re: Saab 93 Turbo
wasnt saabs irs?
and yeah the front legs fit
ashs_cav
Re: Saab 93 Turbo
Post by ashs_cav »
Unsure...just seen somewhere people swap full rear axles to have 5 stud :S
belmont_dazz
Re: Saab 93 Turbo
Post by belmont_dazz »
Saab 900 1994 - 1998
Saab 9-3 1998 - 2000 all b204's red coilpack
Saab 9-3 2000 - 2002 b205's black coilpack
Saab lingo,
Lpt b204 - 154 (1998 - 2000)
Lpt b205 - 150
Fpt - 185 (1994 - 2002)
Hot - 210 ( unsure on year but rare)
Wouldnt worry too much about which one as tbey are so easy to map.
All 3 models based on cavalier so have same axle and hubs. Not independant rears, but a solid axle.
B205's fit but wiring is harder and they arent forged internals. Just as easy to tune and sometimes get better numbers than the b204's as they are lighter/better flowing internals.
Stick to the 204's if i were you! (Red coilpack)
Much much cheaper.
ashs_cav
Re: Saab 93 Turbo
Post by ashs_cav »
Just ma grandad has one and said I could buy it, so red or black its mine :D...just bit of info is better.
1..So the engine , ecu, loom all swao straight over?
Or does the ecu need unlocking?
2..And the front struts with calipers ect and rear exles with bigs calipers ect all swap straight over? :)
Just like to be clear before it begins lol
belmont_dazz
Re: Saab 93 Turbo
Hubs and brakes yes
Loom will need alot of work to make it work if its a 205
Ecu will need unlocking
ashs_cav
Re: Saab 93 Turbo
Post by ashs_cav »
Back axle straight swap yh?
If its a b204 no work required?
Would i still need unlocked ecu?
belmont_dazz
Re: Saab 93 Turbo
Not sure on axle but the hubs unbolt and bolt on to your axle. Think the axles are slightly different. Rear hubs definatly swap over though.
Ecu will be immobolised either way
205 and 204 will bolt in but looms are in need of alot of work. The 204 you can buy the loom adaptor from nige p.
ashs_cav
Re: Saab 93 Turbo
Post by ashs_cav »
So need the saab ecu unlocking.
And need an adapter.
And so itl just be a hub swao then cheers
Do you have a list of changes to the loom that are needed?
And any pictures?
Has he got a phone number?
ashs_cav
Re: Saab 93 Turbo
Post by ashs_cav »
Just found out its a red cover so b204 :)
What exactly needs modifiying on the loom so I can be away and hopefully have no stoppages along the way?
+ adapter
+ ecu unlock
ashs_cav
Re: Saab 93 Turbo
Post by ashs_cav »
Anyone know what pressure you can wind up the turbo up to on standard turbo and everthing before it goes onto overboost or headgasket needs changing??
Re: Saab 93 Turbo
Chip Pan Dan wrote:they do fit, but there not as powerful
Not quite true; the black direct injection cartridge is also present on the 2.3-litre B235R which is 250+bhp as standard without any fettling (found on 95 HOT Aero models etc) and overboost increases the power by 20% (which would be circa 300bhp). Clarkson said this made the Saab 95 HOT Aero "faster in the mid range than a Porsche 911 Turbo". You'd need to ask a few more questions to ascertain whether it would mate to a Vauxhall box as easily as the B204, but I think I remember someone saying the Getrag F40 6-speed from a Vec C will couple up to it.
belmont_dazz
Re: Saab 93 Turbo
They are practically the same blocks in all 4 engines 204/234/205/235
Just different auxilaries. All bolt up to gm gboxs.
The only dow side to the 2x5 engines is they can only take 450nm of torque which is pretty much stage 3 (270hp) but everything internally is lightened and the heads are ported better, thus the name ecopower.
