Td cold start problem
Posted: Wed Jan 21, 2015 9:15 am
by HAIRIBO
My isuzu has started to have a problem. Just had the relay and glow plugs checked and they garage said they were fine. If it's really cold the car takes a while to start. Then will cut out unless revs are held at 1k. But after a few seconds the car is fine. If engine warm starts straight up.
Re: Td cold start problem
Posted: Wed Jan 21, 2015 11:12 am
by HAIRIBO
Havet put any photos up for a while. I.Td got some prefacelift bumpers but waiting for decent weather to paint and fit them
[/URL[URL=http://s210.photobucket.com/user/hairibo/media/DSC_06852_zpsvicfm9ep_edit_1421838257519_zpszdmgil3s.jpg.html]]
Posted: Wed Jan 21, 2015 3:32 pm
by planetc
Have the tappets done, good chance that thats the problem with the cold starting.
Posted: Wed Jan 21, 2015 3:54 pm
by HAIRIBO
Tappets are they the valve 3 shims?
Posted: Wed Jan 21, 2015 5:44 pm
by Greig Sri
From what I remember from my old mk3 astra . There is a lever on the diesel pump for cold starts.make sure it's moving and oiled up. Mine was stuck a bit and I had to hold the revs up for a bit to stop it cutting out.
Posted: Wed Jan 21, 2015 7:02 pm
by HAIRIBO
Anyone got a photo of page lever?
Posted: Thu Jan 22, 2015 2:05 pm
by thegriffin
Have you changed the glowplugs recently? I've
found some don't heat up quickly enough even though
they fit.
Otherwise probably the valve clearances need checking .
The inlets tend to close up.
Posted: Thu Jan 22, 2015 2:33 pm
by Chip Pan Dan
with my corsa when its cold i put the ignition on till the glow plug light goes out about 3 times to help the glow plugs warm up. still so this now even though I changed the plugs not long ago
Posted: Thu Jan 22, 2015 6:32 pm
by HAIRIBO
Had plugs checked. It's now booked in a a garage ran by an ex vauxhall dealership mechanic. He's going to do the valve shims.
Posted: Thu Jan 22, 2015 7:04 pm
by Super89
That will be your problem 100% i bet. I did mine and it starts no problem anymore.
Posted: Thu Jan 22, 2015 7:43 pm
by thegriffin
You could save a few bob if you checked them yourself
first to see if they need doing and then get a garage to
adjust them if necessary.
I do mine every 20000m.
