Clutch pedal stopper
Posted: Tue Mar 15, 2016 1:57 pm
by cavalier1990
Hi
Hoping someone with a cavy that was originally a manual could take a pic of the top of the clutch pedal as when I converted mine to manual there is nothing to stop the pedal being pulled right back towards the driver that results in the clutch cable popping off.
The auto has the mount section for clutch pedal so never needed to change pedal box, but obviously something's missing somewhere and can't see anything obvious missing like where there would be a plate or bar mounted across the section where the pedal pivots. I can drive the car without it falling off but occasionally my foot will slip off pedal and it then springs up and the cable pops off.
Thanks
Andrew
Re: Clutch pedal stopper
Posted: Tue Mar 15, 2016 2:02 pm
by Cavalier342
Strange.. Sounds like maybe a spring is missing or not located properly, the clutch pedal should go up to the dash, so as to free the cable, but it shouldn't spring up, have you had a look underneath for any missing springs or anything?
Posted: Tue Mar 15, 2016 4:09 pm
by cavalier1990
Cavalier342 wrote:Strange.. Sounds like maybe a spring is missing or not located properly, the clutch pedal should go up to the dash, so as to free the cable, but it shouldn't spring up, have you had a look underneath for any missing springs or anything?
What I was meaning about it spring up is imagine you had your foot on the clutch but you had some tension on it then suddenly your foot slipped off the side away to the left, then the pedal pings back up to it's resting position but because of this sudden release of tension it travels past resting point on first release and this causes the cable to pop out the pedal.
I've nothing to refer to so can't really tell what is missing. All I remember doing is removing the clutch pedal and the return spring. The cable has that little locating lug on the end so when I lift the clutch pedal it pops out the hole because the cable won't push inwards, towards bulkhead, but the pedal keeps moving back. I wasn't sure if maybe there was a spring washer or something missing from the cable end to clutch pedal to stop the cable springing out.
Actually looking at diagram here there is nothing missing I can see from mine?
http://gmpartscatalog.com/opel/vectra-a ... ssion-rhd/
Posted: Wed Apr 20, 2016 10:14 pm
by cavalier1990
While reading haynes manual it says that the return spring for the pedal is supposed to clip over the cable and hold it in. Mine's was at the other side so I think when I fitted the pedal I've put the return spring on the other way round.
Posted: Fri Apr 22, 2016 11:15 am
by planetc
The end of the spring does indeed locate in the same hole as the cable, and this is what prevents the cable popping out
