Hi guys. I've searched but can't seem to find anything on these.
My front drivers window dropped inside the door this afternoon, while closing it. First time I've had a window problem in the ten years I've had it.
The white plastic guide seems ok, but the pin on the arm looks as if it has rusted somewhat so the pin on the arm keeps slipping out of the guide. I can't really see it all that well without stripping it out. Trouble is the pin seems part of the whole regulator?
I've seen new guides on Ebay that say for Astra/Cavalier and they include the pivot pin? Does anyone have experience with these?
http://www.ebay.co.uk/itm/GENUINE-VAUXH ... Sw5dNWnoef
Window regulator plastic guide
Re: Window regulator plastic guide
Spoke to the local dealer today. You drill the old pin out, put the new one in the arm and peen the top over like a rivet.
Really looking forward to taking the regulator out, not!!
If it's the same bit that I'm thinking of, I once did a repair on that on my mate's Cavalier, I used a small bolt, put that through the slider and put a nut on the end to secure it. Window still works fine on his motor.
I thought about using a bolt but seeing as I was taking it out I might as well just get the partCavalier342 wrote:If it's the same bit that I'm thinking of, I once did a repair on that on my mate's Cavalier, I used a small bolt, put that through the slider and put a nut on the end to secure it. Window still works fine on his motor.
£5.11 on trade but £5 to me lol
The head of the pin on mine had rusted away, there was only half of the ball of the head left. the plastic slider was fine.
I ground the the back of the pin off with the bench grinder and tapped it out of the arm, much easier than trying to drill it out. Not a bad job just awkward.
I suppose I had better check the rest of the doors!
