Cavalier saab conversation help needed
Hi all am doing a Saab turbo conversation on my cavalier am not mechanic so need help with few things have engine in car it's a b205 engine ino everyone says b204 is best for conversation have a b204 engine but is going into an other project I kept b205 manual gearbox my problem is what clutch cable do use
Re: Cavalier saab conversation help needed
May be worth making your own clutch cable for a project like this.
There are also many companies that make bespoke clutch cables, all for well under £100.
I have heard that the Saabs use a hydraulic clutch.
With than in view, you could try fitting a Vectra-B hydraulic clutch set-up.
The B204 engine that comes with the saab box FM55-501 uses cable and would be a good strong box also easier to fit. Should all go strsight in cav from what ive read before.
Where is the actuator? What kind of setup does it use?
