Engine mounts
Skara
Engine mounts
Post by Skara »
Can anyone confirm are engine mounts same on C16NZ(small block) and C20NE(big block), I was going through the database and they seem to have different part numbers but look exactly the same on first glance ?
Re: Engine mounts
I would expect the parts to be different, as the engines are different sizes.
The NZ2 would probably be the same as the 20NE though, as that is a big block / family 2 engine.
I can check this evening if you like.
Okay - had a look.
None of the part numbers match between the C16NZ and the C20NE engine mounts.
I thought they would use the same mounts, but use different castings / brackets that link the mounts to the engine block and gearbox.
Sadly - they do not.
Skara
Re: Engine mounts
Post by Skara »
Both are manual, thanks
Skara
Re: Engine mounts
Post by Skara »
Darn it, I guess I'm gonna have a hard time changing the engine then, well thanks for checking
