Oil pressure light how long to turn off
Hi all
Something I noticed about the oil pressure light on my 1.8 is it takes quite a while to turn off. Usually takes about 5 secs, sometimes a bit longer to go out, mainly from cold.
From previous experience I realise this can be down to worn big end bearings, there isn't any noise from them so wondered if anyone had any issues with oil pumps or anything else with this engine that caused this kind of symptom?
Andy
vexorg
Re: Oil pressure light how long to turn off
Post by vexorg »
Worn pump?
The pump usually holds all the oil in place, so on any typical vauxhall (or any car), the oil light if off before it starts, ie while turning over.
The only time I've seen it for a few seconds is on an oil change as it has to fill the filter and pipework
David
My old MotorSport 1.8 did exactly the same, no longer than 4 or 5 seconds though. But it was not an issue for me, the gauge I fitted showed the the pressure did come up.
vexorg wrote: Wed Jan 12, 2022 9:40 am Worn pump?
It certainly could be although there isn't any sign (apart from the light taking a while to go out) of oil starvation. Hoping this year I can swap the engine out to the lower mile replacement I've got anyway.
iangsi wrote: Thu Jan 13, 2022 10:09 pm My old MotorSport 1.8 did exactly the same, no longer than 4 or 5 seconds though. But it was not an issue for me, the gauge I fitted showed the the pressure did come up.
Could be the oil pressure switch itself I suppose.
dycie
Post by dycie »
For what it takes to fit an oil pressure gauge it’s a good back up to keep another eye on things.
dycie wrote: Wed Feb 16, 2022 2:54 am For what it takes to fit an oil pressure gauge it’s a good back up to keep another eye on things.
Probably a good idea; I noticed more recently that sometimes the light doesn't even come, so likely a duff sensor.
The gauge is one thing - buying a sensor that works for a reasonable life span is another.
I can't think how many new sensors I have fitted, for them to fail within a year or so.
My current sensor hasn't worked for years.
To be honest - the best thing is to:-
1- ensure that all the wiring from switch to dash is sound.
2 - ensure that where the switch screws into the block is clean and free of congealed oil or filings.
3 - ensure that a good quality switch is used.
And if you are really worried, fit a fresh pressure relief valve and spring.
The oil pump housing is very simple in design and quite easy to work on. Better if you have a pit or lift, so you are working at a comfortable height / angle.
On the bottom of the engine behind the crank pulley.
Robsey wrote: Tue Mar 01, 2022 8:04 am The gauge is one thing - buying a sensor that works for a reasonable life span is another.
Tbh I think it's been like this for a long time so probably another year or two won't matter. I'm also planning on changing the engine for my low miler one so will likely renew the switch when changing it over.
