New clutch cable catching
Joner1983
Post by Joner1983 »
Fitted a new clutch cable the other day after mine snapped about 4 miles from my house :cry: but the metal rod on the gearbox end of the cable seems to catch on the black plastic hole that the cable passes through when the clutch is pressed and pulls the rubber grommet off on the way out:
Any ideas how I can stop this?
1991 H White 1.6L
1992 K Burgandy 1.6L
1989 F Lt Blue 2.0 CDI
1992 J Spectral Blue GSI2000
1995 M Black 2.0 SRI 16v Eco
1995 N Grey 1.8 GLS
1990 G Met. Red 2.0 SRi 20seh
1994 L Grey 2.5 V6
1992 J White GSI2000
So far...............
Re: New clutch cable catching
If it is catching on the bore of the body, then see if the cable is routed at the correct angle over the gearbox and behind the engine.
I would also be tempted to push the rubber grommet thing off the rod, so that it sits over the cable and not the rod.
