Gear selector switch wanted
Can anyone suggest where I can buy an autobox selector switch in the U K? I did buy one but the central operating shaft was damaged. I want to get one cleaned up and sorted ready to fit to my 2.0 8v Mk3s. Both decided to give the flash of doom but one has recovered!
Re: Gear selector switch wanted
I wonder if Envoy CDX has one?
I am sure he converted one of his cars from auto to manual.
It was probably a good 10 years ago, but I am sure he still has some parts stored away.
Sadly not.
Thanks for the information so far. Still hoping!
If it's the same as the vectra one then you can open it and clean it up
David
Yep - they can be stripped, cleaned, reassembled and then set-up again.
Usually a good clean is all you need
I am sure I posted up the TIS information about reassembly and setting up a few years ago.
Look here.
viewtopic.php?f=6&t=16458&p=166410&hili ... ch#p166410
Look here.
Thanks for the information. I understand that they can be opened up and cleaned out but I was hoping to do this on a spare one and then swap it over. The one that I bought to do this turned out to have a damaged and unrepairable central shaft.
The other thought is - could you get a local "machine shop" to make one up, using the damaged one as a pattern?
Obviously pointing out what the damage is on the old shaft.
Certainly worth a try. Thanks for the thought.
