Mk 3 sidelight /indicator
Bernie2017
Post by Bernie2017 »
Can anyone suggest where I could locate a fixing screw for the indicator/sidelight on my 94' 1.7TD. It disappeared recently and I have bought a new unit but it didnt come with the screw to secure it - Many thanks.
Re: Mk 3 sidelight /indicator
Sorry for the long delay.
Part number is 11081551
Listed as a Hex Head self tapping screw.
Size is 5.8mm diameter x 23mm long.
It is a common screw in the Vauxhall catalogue, so may still be available at the main dealer parts counter.
But it sounds very familiar to a screw available from many ebay shops. Similar to the size I used to replace the screws for my front wings during my 2016 restoration.
If vauxhall draw a blank, then...
You are looking at No12 Acme Screws.
Nearest length would be 7/8" or 22mm if you can find them.
Standard length is 3/4" (19mm).
With the odd supplier doing 1" (25.4mm).
See here.
https://www.ebay.co.uk/itm/161837981265 ... R7q5o8GgYw
