does anyone know if the engine undertray fitted to early gsi's will work on a v6? i know the chassis is the same fittings but is the flap where you can reach into the engine in the 'wrong place' because of the different engine layout?
ta
cavalier engine undertray
- dave's.veccy
Re: cavalier engine undertray
Although the V6 engine is bigger on top, below the heads etc is the same width as say a XE. The sump is in exactly the same place so yes that engine cover will fit without any problems
