a blonde question
Posted: Tue Sep 08, 2009 7:46 pm
by crocadmin
dumb i know but wot does a EGR valve do? & owning a c18nz where is the idle control valve located ? fanks
Re: a blonde question
Posted: Tue Sep 08, 2009 8:22 pm
by Gaz
Exhaust Gas Recirculation basically takes a bit of exhaust fumes and reburns it to make the emissions a bit cleaner.
Isnt it the silver redbull can thing between rocker cover and the inlet on a couple of rubber pipes (ive not owned an 1.8)
Posted: Thu Sep 10, 2009 6:17 pm
by crocadmin
okies ta so if i take off the egr valve i could run the risk of high emissions @ mot time ? as 2 the redbull can thing i cant see 1 under my bonnet ?
Posted: Thu Sep 10, 2009 9:55 pm
by Cavalier342
Taking it off would cause oil and grime to spill everywhere which is not recommended. As for MOT i cannot say what happens, but the E.G.R. valve is... look just behind the cam cover, top of the engine, before the big plastic top hat, with big GM written across it. There will be a silver- ish plate with a hose running behind the top hat. That itself is the EGR valve on the 1.8 blocks. Considering its the C18NZ (fuel injection) block. Just 2 bolts to undo. Quite tricky to get to, but i cant remeber quite which size they are. Refer to a Haynes Manual or such. Cleaning it is simple enough, plenty of valve cleaner or WD-40 and a brush, and you should get it clean quite quickly. To be fair, it does its job well and will get through an MOT emissions test quite easily, but if not, just follow the simple steps
Andrei.
Posted: Thu Sep 10, 2009 10:45 pm
by Mort
The missus' mk4 Astra developed hesitation that was traced to a worn EGR (it was kinda juddery under partial load), so rather than spend a fortune replacing the thing or messing around trying to clean it I simply blanked it off. Since then we have found that the car feels like it pulls a little stronger under partial accelleration. Have the first MOT for it coming up so I'll find out then if it fails the emissions test...
Posted: Fri Sep 11, 2009 5:32 pm
by crocadmin
342 i think we,v got r wires crossed m8y, i know where the EGR valve is, its where my idel control valve is located that i was after some help lol
Posted: Fri Sep 11, 2009 8:17 pm
by Envoy CDX
Go to Vauxhall, order the EGR blanking kit for the c18NZ (the part number is in one of Adam5344's post's) it's about £9 or something, made a difference to the running of his car.
Posted: Mon Sep 14, 2009 6:12 pm
by crocadmin
fanks guys uv helped loads wiv the EGR valver.........could do wiv some pointers as to where the idle control valve is pls
Posted: Mon Sep 14, 2009 9:21 pm
by Gaz
If your engine looks like that, its the silver can thing thats attached to the pipe coming off near the throttle body, pretty much dead centre of the picture
Posted: Tue Sep 15, 2009 5:40 pm
by crocadmin
nice one GAZ but alas no it doesn't mine is a 1.8 single point injection in a 95 expression .
Posted: Tue Sep 15, 2009 6:24 pm
by Gaz
its the small black cylinder attached to the throttle housing sort of D sized battery thing.
Posted: Mon Sep 21, 2009 7:55 pm
by crocadmin
that does,nt ring any bells either lol but next time im under the bonnet i,ll av a good look, picked up a s/h EGR valve 2day...gona clean it up & then swap it over...wish me luck
Posted: Tue Sep 22, 2009 5:36 pm
by Colorado
http://www3.snapfish.co.uk/slideshow/Al ... _90823984/
Is this picture angle any better. I think it is the circular metal bit behind the engine block?
Posted: Tue Sep 22, 2009 7:31 pm
by crocadmin
colorado if u r referring to the EGR valve ? this is now sorted but fanks for the picy
