Coil
shuviteer
Coil
Post by shuviteer »
Is my '95 2.0ltr Cav fitted with a ballasted coil or not as I want to get a sports coil with a bit more spark power and don't want to get the wrong type !!!! :|
fire26662
Re: Coil
Post by fire26662 »
Use a multimeter between the positive terminal and earth, turn the ignition on. If you see battery voltage then no if its lower then yes
shuviteer
Re: Coil
Post by shuviteer »
I'm presuming you mean on the coil and not the battery !!???
Also, if it doesn't register anything for a non ballast, how can it register lower ???? Or have I misunderstood your reply ? :?:
fire26662
Re: Coil
Post by fire26662 »
I do apologise for not making it clear. I meant the coil just connect a voltmeter between the positive side of the coil marked 15 and a good earth. Switch the ignition on and measure the voltage. If you see between 9 and 11 volts you have a ballasted coil. If you see 12 volts and up (depending on the charge in the battery typical 12.6 volts) then it is unballasted. I have a Cavvy SRI C20NE and that is 11V and has a ballast resistor.
shuviteer
Re: Coil
Post by shuviteer »
Cheers, will try it out later. :thumb
