Coil
Posted: Mon Feb 22, 2010 8:58 pm
by shuviteer
Is my '95 2.0ltr Cav fitted with a ballasted coil or not as I want to get a sports coil with a bit more spark power and don't want to get the wrong type !!!!
Re: Coil
Posted: Mon Feb 22, 2010 9:21 pm
by fire26662
Use a multimeter between the positive terminal and earth, turn the ignition on. If you see battery voltage then no if its lower then yes
Re: Coil
Posted: Tue Feb 23, 2010 12:10 am
by shuviteer
I'm presuming you mean on the coil and not the battery !!???
Also, if it doesn't register anything for a non ballast, how can it register lower ???? Or have I misunderstood your reply ?
Re: Coil
Posted: Tue Feb 23, 2010 1:38 pm
by fire26662
I do apologise for not making it clear. I meant the coil just connect a voltmeter between the positive side of the coil marked 15 and a good earth. Switch the ignition on and measure the voltage. If you see between 9 and 11 volts you have a ballasted coil. If you see 12 volts and up (depending on the charge in the battery typical 12.6 volts) then it is unballasted. I have a Cavvy SRI C20NE and that is 11V and has a ballast resistor.
Re: Coil
Posted: Tue Feb 23, 2010 1:51 pm
by shuviteer
Cheers, will try it out later.
