just a quick question, i have a post in the wanted section for some 40mm lowering springs for a cav saloon, mines a 95 16v, but has the rear beam axel. i have been offerred a set from jeffjeff450 a set but his cav that he's breaking is a v6 cdx, will they fit mine, i dont think the cdx has irs?
sean999
lowering springs, same on a saloon and a hatch?
Re: lowering springs, same on a saloon and a hatch?
Should be fine, as long as they are both beam then they are interchangeable.
Dunno if there is a rate difference on the v6 though?
They'll be fine, the front may sit a little higher than in his due to the weight. But there isnt that much difference between an ecotec 16v and v6 cavaleir to worry. If cheap enough then go for it!
Springs in question were off a 2.0 8v LS hatch I used to have not off the v6 if that helps.HAIRIBO wrote:They'll be fine, the front may sit a little higher than in his due to the weight. But there isnt that much difference between an ecotec 16v and v6 cavaleir to worry. If cheap enough then go for it!
