BRAKE DISKS
BRAKE DISKS
HI.I AM LOOKING FOR DRILLED FRONT DISKS FOR MY CAV 2.0 8 VALVE WITH A CAT. I LOOKED ON EBAY BUT CAN ONLY FIND ONES FOR A 2.0 16VALVE. THEY SAY THE CENTRE RING DIAMATERON BRAKE DISK IS 60.MM. HAVE ALL I MEASURED MINE AND IT IS 55MM. ANY HELP WILL BE APPRECIATED.
Re: BRAKE DISKS
i think you have measured the diameter the wheel sits on, then there is a lip where the disc sits. 256mm 2.0 brakes are 60mm internal diameter - http://www.autopartoo.com/oem/acl/adg08255cu7j.html
have some brand new std high quality 2.0 ones here. much better than crap quality drilled ones which will crack etc. usually poor quality heat treatment on those.
