SRi brake upgrade
Re: SRi brake upgrade
Just use decent quality pads. Cheap crap will fade, but for a one off random possibility that you might need to make an emergency stop I see no benefit to doing anything more than that.
Telegram Sam
Post by Telegram Sam »
That's about the sum of it. Any personal views on "decent quality pads" such as or in addition to what's been mentioned above? (which I confess I still have to look into properly ..). I'm assuming that one can do a bit better than standard GM's without spending a fortune.
Telegram Sam wrote:That's about the sum of it. Any personal views on "decent quality pads" such as or in addition to what's been mentioned above? (which I confess I still have to look into properly ..). I'm assuming that one can do a bit better than standard GM's without spending a fortune.
Discs and pad kits on Trade you can pick up from Vauxhall for around £54 rear or similar for the fronts.
Not exactly bank breaking.
Standard should be fine really.
paul_34
Post by paul_34 »
I overhauled my front calipers about 2 years ago. New dust boots and seals each side £21 I think it was from my Vauxhall dealer. I wanted genuine pads and discs a few months ago but the best they could do them for was about £84. In the end I went to my local factor and asked for Mintex pads and discs £54. They are brilliant on the td. Nice and progressive and pull up well sharp emergency braking :D Only problem I've had with them is brake squeal on the one side. Apparently they are known for this as I found out while searching the web. Still, they stop the car lol
paul_34 wrote:I overhauled my front calipers about 2 years ago. New dust boots and seals each side £21 I think it was from my Vauxhall dealer. I wanted genuine pads and discs a few months ago but the best they could do them for was about £84. In the end I went to my local factor and asked for Mintex pads and discs £54. They are brilliant on the td. Nice and progressive and pull up well sharp emergency braking :D Only problem I've had with them is brake squeal on the one side. Apparently they are known for this as I found out while searching the web. Still, they stop the car lol
you can pick up shims that goes on the back on the pads to prevent the squeal - however, cleaning up the carrier and adding a small bit of copper slip to the contacting points for the pad guides and lessen and prevent this in future.
paul_34
Post by paul_34 »
I stripped them down three times :x not as bad as they were but still a bit of a squeal on the nearside.
Read the first post on this forum :lol:
http://www.rsownersclub.co.uk/rsocbb/sh ... p?t=136938
