rear brakes
rear brakes
Can anyone tell me where I could get the pressure reducing valves that scrrw into back flexis, not sure if thats what they are called, been to Vauxhall-watts -eurocarparts no joy at all. Got new brakepipes and flexis but would like to renrw these valves, any help appreciated
Re: rear brakes
These can be a bugger to get, they are brake bias/accumulator/compensation/regulator valves depending on where you look for them.
Look up Brake Compensator Valve on ebay, there is normally a seller with these.
Re: rear brakes
Thanks pal for your help, ill look that up, are they on othet cavys calibra astras etv if so are they the same, reckon they should be
Re: rear brakes
I found mine on eBay. £14 a side which is better than the £120 at Andrew Page or £146 from Vauxhall
Re: rear brakes
Ive searched ebay, there s ones on it for £15 ive sent a message to make sure they fit, thanks once again
Re: rear brakes
Ive renewed all the brakepipes, brandnew calipers and shoes pafs and discs now hopefully get the fluid in once they come, yir a star
Re: rear brakes
Motorquip ones aye?bigsilver wrote:Ive searched ebay, there s ones on it for £15 ive sent a message to make sure they fit, thanks once again
Re: rear brakes
Not sure ill check the now
Re: rear brakes
Its says FIRSTLINE FBV5043
Re: rear brakes
Sounds familiar actually.
Re: rear brakes
I noticed another seller selling same item but states for mk2 cavalier upto 1988 1600cc -1800cc, youd think theu would be the same, see what happins
Re: rear brakes
From what I understand, they are designed differently due to the weight of the vehicle.bigsilver wrote:I noticed another seller selling same item but states for mk2 cavalier upto 1988 1600cc -1800cc, youd think theu would be the same, see what happins
Re: rear brakes
Should fit, shell is more or less same weight as other cavys, unless ive missed a heavy object, suppose some fat chuff in the back lol
Re: rear brakes
did you get sorted then?
Re: rear brakes
I ordered one of ebay but was too Big, cant get them anywhere, ive put the brakepipe right onto thenew flexis for now, cqn always cut them back if I manage to get any which I doubt very much, unless someone knows someone with them, thanks for your interest, much appreciated
Re: rear brakes
THink there are two types 10mm for early cars and 12mm for later cars.
Re: rear brakes
Didn't the later models have them mounted on the bulkhead or master cylinder? I can't remember seeing these under the back of mine :/
