Whats the difference in the brake hoses from the v6 and the rest of the FWD cars?
As I'm seeing a differnet part number.
When I converted my 2.016v to using vectra calipers my standard hoses worked.
I I used cavalier v6/turbo calipers are th hoses different?
I currenlty doing a conversion on my Diesel. 95 spec rear discs and turbo/v6 fronts.
so what do I do about the hoses?????
Brake hoses
Brake hoses
Re: Brake hoses
After a long search I think its the rear hoses that are different. type is Female-female, the other is female-male
Re: Brake hoses
Ive got a v6 Master cylinder and servo that would go well with your setup
Re: Brake hoses
You need to make new brake lines from the flexi to the caliper anyway so it really doesn't matter at all.
Re: Brake hoses
The braided type I've gotten come as a female/female fitting hose! But it comes with an adaptor to make one end male.
