single v belt
joe cavalier sri
single v belt
Post by joe cavalier sri »
hi going to be converting my sri to manual steering doing away with power steering so removing the power steering pump my c20xe engine is a 1990 with single v belt fitted what size belt would I need to use and what would the belt be off when I remove the pwer steering pump cheers :thumb
Re: single v belt
Why would you want to do that ? :scratch
Re: single v belt
Obviously so he can work out while driving :lol:
joe cavalier sri
Re: single v belt
ilovedmymantas wrote:Why would you want to do that ? :scratch
more feel of the road
Re: single v belt
Are there not 2 separate belts?
You set alternator at almost loose tension, get some string wrap it around the pulleys, Mark where it crosses then measure length. you then know size of belt
Re: single v belt
If it's a single belt it's not a v, it's a multi v. You might find that the tensioner won't work if you change the belt route by removing the ps pump.
vauxtillidie
Re: single v belt
Post by vauxtillidie »
i think troy is right, theres 2 seperate belts iirc so the bottom pulley takes 2 belts one to the alternator one to the pas pump so really you just remove the pump one of the belts and leave it as it was
this only applies to the early single v setup
2006 Flame Red Astra VXR 19's, AFL, Headlamp Washers, Cruise Control, CD70+ AUX In, CID, Bluetooth, Sight & Light, Powerfold Mirrors, DDS/TPMS, Park Pilot, Check Control, Speed Locking - All Retrofitted by me :)
vauxtillidie
Re: single v belt
joe cavalier sri
Re: single v belt
sorry its me beaing thick lol sound cheers lads
joe cavalier sri
Re: single v belt
will I get any warning lights on my dash ? if so how do I remove iiit or is it just a matter of removing the bulb lol :scratch
Re: single v belt
Warning light for what. A missing belt, I don't think Cavaliers have that facility
joe cavalier sri
Re: single v belt
btcctroy wrote:Warning light for what. A missing belt, I don't think Cavaliers have that facility
I thought they have a warning light on dash for power steering ? :scratch
Re: single v belt
Nope.
joe cavalier sri
Re: single v belt
Cavalier342 wrote:Nope.
ok sound that's me going back in time to manual steering lol see how different it is from manual to power assisted
Re: single v belt
Well I'm not the strongest of people but I tried to roll my V6 down the drive the other day with the engine off, and I could barely turn the wheel :lol:
As for feeling the road, I suspect you may be right, as it will be more mechanical rather than hydraulic. But you may put more pressure on the column.... At least that's what it feels like to me.
joe cavalier sri
Re: single v belt
Cavalier342 wrote:Well I'm not the strongest of people but I tried to roll my V6 down the drive the other day with the engine off, and I could barely turn the wheel :lol:
power steering is a luxuary how the hell we drive cars befor power steering lol
Re: single v belt
Ps racks are geared different from manual racks, much higher ratio. If you just take the belt off you'll find it a bitch to park.
Re: single v belt
I agree mate, but my first car, a 91 Colt 1.3, never even needed it as it didn't weigh anything.
With Cavaliers, maybe the basic 1.4 models didn't need it but anything above it definitely does! :lol:
cavbec1994
Re: single v belt
Post by cavbec1994 »
there is more feel but trust me my ps pump went it was a bugger to drive when parking of 3 point turns apart from that it was ok
thegriffin
Re: single v belt
Post by thegriffin »
We didn't have power assistance years ago.But then
we didn't have low profile tyres either !
Good luck when you need to get out of a tight
parking space.
