Front wheel bearings
joe cavalier sri
Post by joe cavalier sri »
Hi just a quick question does the front wheel bearing have a bearing bigger than the other as I've pressed one in and fits perfectly and the other pressed out but the new one is smaller the outer diameter so I matched it up to the old one and its same size now is there a sleeve or are they sided it's strange and confused me I'll get some pictures to to show you what I mean :thumb
Re: Front wheel bearings
4 stud and 5 stud bearings are differant
joe cavalier sri
Rate pictures this is the hub with bearing pressed out.
Drivers side hub pressed in nicely.
With the new bearing in that's lose.
With the old bearing in lose but was solid before it was pushed out ?
Short vid.
http://vid1302.photobucket.com/albums/a ... qu4aey.mp4
It's confuseing me as the old ones pushed out with the press and fitted perfect the old ones are the same size as both new ones but one new bearings fit and the other don't ? :scratch
joe cavalier sri
There 4 stud not 5 stud :thumb
