Silicone based brake fluid or Blue brake fluid
- dave's.veccy
Has anyone used either of the above??
Ive done a couple of track days in a couple of cars ive owned and i can say brake fade is scary. I feel my brakes are ok on this Veccy for what they are but as i feel the fluid is due a change, i was thinking of getting one of the above.
I know its pricy but its drain & fill once and then forget sort of stuff
any advice is great
any advice is great
Re: Silicone based brake fluid or Blue brake fluid
id be just using 5.1 and changing it before you track it, either that or get bigger brakes for more surface area to dissipate the heat.
- dave's.veccy
coolGaz wrote:id be just using 5.1 and changing it before you track it, either that or get bigger brakes for more surface area to dissipate the heat.
Are V6 brakes any different to 2lt Auto brakes
Im thinking of getting or making the police spec wishbone scoops to help with cooling too
288mm
the ducts will probably help but i always wanted to do huge ones from behind the fog lights to each wheel
- dave's.veccy
Ive got 5 stud discs as standard bud
Sounds like an idea, i dont use the fog lights anyway
I forgot you had the vec now, so ive edited my other post.
I can sort you out with 335mm 6 pot porsche setup but you'd need a lie down if i told you the price
- dave's.veccy
Easily done
lol im sitting down
lol im sitting down
£600, probably as expensive as most vectras these days
- dave's.veccy
wow, thats nearly twice what i paid for the car
exactly, i reckon the car would do stoppies if they were fitted.
- dave's.veccy
Knowing me, id have it on its roof within a week
- dave's.veccy
