Suspension advice
jadiecakes
Suspension advice
Post by jadiecakes »
Hi
I own a Sri and an ls , can I use the sri suspension on my ls as wanting to upgrade and make a sri replica with body kit etc
Re: Suspension advice
Hi there,
The SRi suspension will fit the LS,
but the SRi parts should be slightly shorter / lower than standard LS parts.
So remember to use both front and rear springs and dampers.
The SRi body is the same as all other trim level bodies except a proper GSi body with independent rear suspension.
So all trims and parts will be interchangeable between the LS and SRi
For information,
I have SRi specification suspension and interior on my LS, with an SRi oval exit Bosal exhaust back box waiting to be fitted.
As for SRi trims, you will struggle to find all the body and door mouldings for an SRi with the red stripe / insert in them.
The bumper moulding inserts are a little easier to source... but not much easier...
