What's the PCD?
What's the PCD?
what is standard PCD for 5 stud cavs?
and what does PCD actually mean
Re: What's the PCD?
Re: What's the PCD?
I like these, but at £450 per wheel I think they may be a little pricey
- Cavyman_130
Re: What's the PCD?
wow they are rather expensive wheels. is the PCD not just the dimensions of the wheel? could be very wrong though,
Re: What's the PCD?
17x7.5
5x114.3 PCD et 45
is the size I was looking at... I'm not sure if that's the price, my magazine states £450 per SET
5x114.3 PCD et 45
- Cavyman_130
Re: What's the PCD?
called them and the £450 is per set without tyres, also enquiring whether they can do 110PCD on the 5 stud pattern
Re: What's the PCD?
it means pitch circle diameterSquig wrote:what is standard PCD for 5 stud cavs?
heres an explaination
http://swinny.net/Cycling?e=3005
Re: What's the PCD?
lam sure its a 5x110 pcd
Re: What's the PCD?
yeah Vaux 5 stud is 5x110mm was gutted cos my toyotas are 5x100mm, so i cant use them on a astra or vectra.
its basically the distance between the centre of a stud hole to the centre of the next hole.
Thank god you dont own a 1 litre saxo, they are 3 studs!
Re: What's the PCD?
Yep....Vaux 4 studs are 4x100 and Vaux 5 studs are 5x110
