Adjustable camber kits?
where can I get good quality adjustable camber kit for the front and rear of my v6 cav hatch, and for a 4x4 cav?
Re: Adjustable camber kits?
http://cav16.co.uk/prices1.htm
4x4 Rear Wheel Camber Kit
+ This kit is the multi-functional kit to adjust both camber and castor of the rear wheel set
+ Fitting is essential for lowering any of the 4x4 models, to avoid potential damage to the tyres and transfer box.
+ The ideal maximum lowering height is 30mm with an absolute maximum of 40mm. Lowering over 40mm may impair achieving the correct toe setting.
+ Price includes delivery into the UK mainland island.
+ Delivery Ex-stock is 2-3 days else 2-3 weeks.
+ Fitting instructions
+ Workshop Manual article
£198.52
Found one by Dorfbrunnen sold in uk by Cav16.co.uk (they also do sports transfer boxes)
Ive seen the front kits as cheap as £20 but the key thing is who is gonna set it up for you?
weeeeeeell... if your after 0 degrees then a plumbline should be adequate... once I've sorted this move then I'll find my track mag that breaks it down and post a how to.
oh and where have you seen the front camber adjustment
