cav pulling to left
- steven240374
cav pulling to left
Hi all i have just managed to get my cav back after its had 7 months with a new owner but now it pulls to the left sometimes alot and sometimes it will drive straight what could this be hope someone can advise
Re: cav pulling to left
could be track rod ends?
or a sticky caliper maybe?
olso check the lower arm could be bent .Mine is dong this so I am getting the tracking done, whats the ns/f trye like
on the inner/outer edges any wear
Is there a vibration with it that as you increase your speed increases aswell cos it could be a slack wheel bearing
You will hear wheel bearing when turning left on full lockRage wrote:Is there a vibration with it that as you increase your speed increases aswell cos it could be a slack wheel bearing
check the tyre pressure. this wiil cause the car to pull. But most of the time its tracking .I did have a seized caliper when I changed it
still pulls to the left
