How2 - explain sodium filled valves...
An index of useful guides designed to help you care for and maintain your Mk3 Cavalier
Locked
Specifically sodium-filled in a misnomer, they should be called Sodium-cooled valves...
An exhaust valve with a hollow stem that is partially filled with metallic sodium. When the valve gets hot enough (138°C), the sodium melts and moves up and down in the valve stem. The sodium absorbs heat from the hot valve head and carries it away to the outer part of the stem and then into the valve guide in the cylinder head and next to the cylinder head itself. This circulation cools the valve head and thus the valve is allowed to run at a lower temperature.
Simple...
Re: How2 - explain sodium filled valves...
you have too much time on your hands :wall :lol:
far far too much...
Locked
