How2 - Door Loom Connector Wiring Map
Locked
Just a brief post so far,
I am looking at fitting electric mirrors sometime in the future, so I thought that I'd best investigate what goes where.
So here is a pin-out of the connector.
Viewed from the wire side. (Loom side of the door connector, not the pin side)
Here is a complete wire listing
Door Connector
(X31 for Driver's Door) (X34 for Passenger Door)
1 - No Connection
2 - BLACK/WHITE - Mirror Demister - Feed From Rear Window Demister Switch
3 - BLUE - Mirror Motor /\ \/ (Up/Down) (Doors looms linked)
4 - GREY - Mirror Motor < > (Left/Right) (Doors looms linked)
5 - GREY - Kerb Light - Door Switch contact wire
6 - BLACK/BROWN - Mirror Motor Park Position
7 - RED/YELLOW - Central Door Locks - Unlock
8 - BROWN/RED - Central Door Locks
9 - BLACK/GREEN - Mirror Motor Park Position
10 - BLACK/RED - Central door Locks - Ignition Live Feed
11 - BLACK - Ignition Live for Mirrors - Fuse 12 = 10Amps Drivers Door Only
12 - RED/WHITE - Electric Windows Pinch Guard
13 - BLUE or YELLOW - Door Speaker +ve
14 - No Connection
15 - BLACK/BLUE - Central Door Locks - Deadlock (Doors looms linked)
16 - BROWN/WHITE - Central Door Locks - Module & Doors looms linked
17 - BLUE/RED - Windows \/ (Down)
18 - GREY/GREEN - Windows /\ (Up)
19 - No Connection
20 - BLACK/RED - Mirror Ignition Live Feed
21 - BROWN/BLACK - Central door Locks and Windows - Full Closure
22 - BROWN/BLUE or BROWN/YELLOW - Door Speaker -ve
23 - PRE-FACELIFT ONLY - RED - Windows and Kerb Light Battery Live - Fuse F30 = 30Amps
24 - No connection
25 - BLACK/YELLOW - Central Door Locks - Module & Doors looms linked
26 - WHITE/BLACK - Mirror Park Position relay feed
27 - No Connection
28 - No Connection
29 - BROWN - Door Loom Earth
30 - FACELIFT ONLY - RED - Windows and Kerb Light Battery Live - Fuse F30 = 30Amps
and here is the listing broken up to each component/ module
Front Door Connectors
Broken Down Into Modules
AUDIO SPEAKERS
CENTRAL DOOR LOCKING
7 - RED/YELLOW - Central Door Locks - x31 only
8 - BROWN/RED - Central Door Locks from Module - X31 only
10 - BLACK/RED - Central door Locks - Ignition Live Feed (Module)
21 - BROWN/RED - Central door Locks and Windows - x34 only
25 - BLACK/YELLOW - Central Door Locks - Motor Common
ELECTRIC MIRRORS
2 - BLACK/WHITE - Mirror Heater
3 - BLUE - Mirror Motor /\ \/ (UP/Down)
6 - BLACK/BROWN - Mirror Motor Park Position - Where Fitted
9 - BLACK/GREEN - Mirror Motor Park Position - Where Fitted
11 - BLACK - Ignition Live for Mirrors - Fuse 12 = 10Amps - X31 Only
26 - WHITE/BLACK - Mirror Park Position relay feed - Where Fitted - x31 only
ELECTRIC WINDOWS
12 - RED/WHITE - Electric Windows Pinch Guard - Where Fitted
21 - Facelift Only - BROWN/BLACK - Windows - Full Closure
23 - Pre-Facelift Only - RED - Windows and Kerb Light Battery Live - Fuse 30 = 30Amps
30 - Facelift Only - RED - Windows and Kerb Light Battery Live - Fuse 30 = 30Amps
KERB LIGHTS
I will post up connectors for the rear doors in due course.
Locked
