Rubber seals
T1BBST3R
Rubber seals
Post by T1BBST3R »
Anyone know where to get the rubber indicator seals?
Also, the seal in the picture here needs replacing https://www.flickr.com/photos/76806244@ ... res/k9YP4m.
Does anybody know where I can get one from? I'm assuming you can just tear it off and unbolt the rail it fixes to to put on a new one. I think it's glued in place.
Thanks in advance
Re: Rubber seals
Link says I don't permission to view!
T1BBST3R
Re: Rubber seals
Post by T1BBST3R »
New link; https://www.flickr.com/photos/76806244@ ... ed-public/
Re: Rubber seals
The rubber seals between the sill and the doors are the following part numbers.
Sill Weather Strip Left = 90224973
Sill Weather Strip Right = 90224974
Prices are £35 and £40 respectively from Genuine Parts Search.
Check out the two links below.
http://www.genuinepartsearch.co.uk/
http://ecat24.com/opel/catalog/part/1/3 ... 8893,8889/
The strips are clipped on to a row of pins / pegs.
The pins / pegs look like the heads of flat-headed nails.
T1BBST3R
Re: Rubber seals
Post by T1BBST3R »
Excellent! Thanks Robsey, great site, as it's for the drivers side unless told otherwise I shall get the right hand strip because the other one is o.k.
Regards
Re: Rubber seals
You are most welcome
It was a total ball-ache trying to find those strips... took me ages.
Typical for how Vauxhall catalogue and categorise parts. :scratch
I shall point out that I am not on commission to either of the websites in those links. - ha ha. :no
It would be nice if I was.. :P
I am sure it is item 13 in the drawing / diagram. :geek:
T1BBST3R
Re: Rubber seals
Post by T1BBST3R »
Oh, didn't check that one, yes item 13 looks good. There used to be one with all the fitting diagrams called, I think, partsbase aswell, thats the only one I knew of but it isn't there anymore, most appreciated, will be book marking those sites for future use.
