bonnet lifters for cav
oilburner85
Post by oilburner85 »
does anyone know if you can buy bonnet lifters for the cavalier? me and a mate have been searching round for about a week and carnt find any anywere. if you carnt buy any has anyone done this before? if so how. many thanks
Re: bonnet lifters for cav
ive got mk3 astra fitment ones on mine.
oilburner85
were can you buy them from? and do they go straight on?
oilburner85
just to be clear about what im on about when i say bonnet lifters i dont mean the struts for holding up the bonnet i want the bonnet to be raised at the back when closed. sorry if i wasnt clear on my post!!
ahh bonnet lifting blocks, ive seen them on ebay in the past.
But you may as well just use some longer m8 bolts and some washers? its just going to be a block of alloy with 2 holes drilled into it.
Use anything that can be made to achieve the height you want,
I would probably use blocks of ABS plastic or similar,
Packing washers are the cheapest and simplest solution, with an ability to adjust simply by adding / removing some of the washers.
oilburner85
Re: bonnet raisers for cav
if i just put a longer bolt and some washers on (because the hinge is angled on the cavs) wont it just bend the hinge???
carnt find any on ebay its so frustrating :x
Pimpvehicle
Post by Pimpvehicle »
I believe that almost every car uses m6 bolts for the bonnet, in my previous cars i just worked out the length off the thread that goes into the bonnet and got longer ones by the desired amount. I raised my ZS an inch but it does really look like your bonnet it broken but it has been proven to reduce under bonnet temperatures. To be totally honest I don't know if it will work on the Cav due to the vents working of the duct behind the engine...
But no, when i raised the ZS's bonnet the catch didnt need adjusting and worked fine, just make sure you drop it harder to make sure it shuts.
Just get some longer bolts and washers job sorted, but if you want a neat and tidy job search ebay as they sell solid cylinders or blocks that fit most cars. Theres an awful lot of them for Saxos which i believe use m6 bolts aswel so get some of the Saxo ones if you cant find any Cavalier ones.
http://shop.ebay.co.uk/?_from=R40&_trks ... Categories
Click above :)
Also remove the weather strip if the cav has one.
