does any one know how to take the black strips off that run front to back of the car, inside the doors at the bottom of the doors (the rubber bit)
the bit in between the two red lines
any help will be appreactated
sorry if i have put this one in the wrong place
black rubber bits
Re: black rubber bits
credit card should do it (a dead one ofcourse)
of something thin as its just clipped on.
They eliminate noise incase your thinking about binning them.
ok bud cheers
im not goin to bin them i an just going to take them off to see if i have any fust behind then and i can clean there aswell
IF I were you, I'd coat the area under the strip with something anti corrosive as they often do go there.cavyboi wrote:ok bud cheers
But as they are part of the full sill - what condition are the sills in?
cheers bud i will coat the under neath of them as i am going to take them off
the sills are not that bad to be honist bud
cheers bud
