Hi all
I'm sure I've seen a post regarding this but can't seem to find it
My sunroof will tilt but not slide any ideas why and is it an easy fix ?
Any help and info as always much appreciated
sunroof won't retract
Re: sunroof won't retract
Is it manual or electric?
If manual, it may just need a bit of force, then oil the runners where the sunroof mechanism slides back on, then work it until it frees up. If electric, could either be a switch fault or motor fault, as there is no relay as such for that.
Lockout catches, search through deeksins posts I detailed this last summer and h e took photos.
Its electric
Will check deeks thread thanks
Hi mate thanks to advice from planetc I sorted mine look through this hard to explain the fix but any questions let us know oh and watch the roof is easily dented with elbows
viewtopic.php?f=21&t=5348&start=300
Cheers to all
Will have a look if time ever permits !!
