clock removal
bellers
clock removal
Post by bellers »
how do you take the clocks out as i need to fit a new speedo cable?
had a we look round but didnt want to pull to much incase i broke anything
thanks
jonny
Re: clock removal
OK.
Turn Steering wheel quarter turn to the left, remove cap and screw, centre and the same for the right.
3 screws out of the ignition cowling's underside and that should allow you to remove the bottom and top :)
Gently prise the lower trim under the clocks towards you (pull gently from the middle should unclip it)
You should now have 4 exposed screws, undo the top 2 and remove the upper trim out which will reveal all 3 screws for the clocks.
You will need to gently manoeuvre the clocks out (or you can remove the steering wheel for easy access)
It's faily straight forward to do :)
bellers
Re: clock removal
Post by bellers »
thanks ill give it a go at the weekend. hand bits of round steering coloumn but didnt want to pull to hard at the next bit just incase
Re: clock removal
bellers wrote:thanks ill give it a go at the weekend. hand bits of round steering coloumn but didnt want to pull to hard at the next bit just incase
How'd it go then?
bellers
Re: clock removal
Post by bellers »
got it sorted thanks
worst bit was screwing new cable into gearbox. hardly get my hand it lol
Re: clock removal
glad to hear its sorted :)
