how do you take the clocks out as i need to fit a new speedo cable?
had a we look round but didnt want to pull to much incase i broke anything
thanks
jonny
clock removal
Re: clock removal
OK.
Turn Steering wheel quarter turn to the left, remove cap and screw, centre and the same for the right.
3 screws out of the ignition cowling's underside and that should allow you to remove the bottom and top
Gently prise the lower trim under the clocks towards you (pull gently from the middle should unclip it)
You should now have 4 exposed screws, undo the top 2 and remove the upper trim out which will reveal all 3 screws for the clocks.
You will need to gently manoeuvre the clocks out (or you can remove the steering wheel for easy access)
It's faily straight forward to do
Re: clock removal
thanks ill give it a go at the weekend. hand bits of round steering coloumn but didnt want to pull to hard at the next bit just incase
Re: clock removal
bellers wrote:thanks ill give it a go at the weekend. hand bits of round steering coloumn but didnt want to pull to hard at the next bit just incase
How'd it go then?
Re: clock removal
got it sorted thanks
worst bit was screwing new cable into gearbox. hardly get my hand it lol
Re: clock removal
glad to hear its sorted
