What's behind the front driver's wheel arch?
ronnie1995
Post by ronnie1995 »
Hi folks,
Got the cavalier back on the road after making the mistake of getting the astra.
There is a hissing noise coming from the drivers side front wheel arch and by looking through the crack between the door there seems to be a cylindrical shaped object with pipes coming from it and seemingly where a pipe has perished or something, would this be something to do with the fuel system as the engine doesn't run as steady as it should?
Ron
Re: What's behind the front driver's wheel arch?
Yes thats the fuel carbon canister, it has a vacuum pipe going to it if i remember rightly which is probably what the hissing is if its split.
Yes - it is the carbon canister
It is also likely that you'll get fuel vapour leaking too,
if you have a split cannister or vacuum pipe.
Vacuum leaks are more of a problem on the single point injection engines as the emissions control system works on manifold vacuum pressure (MAP) whereas the multi-points work on air-flow through the induction trunking.(MAF).
