heaters
cunningham
heaters
Post by cunningham »
ok a weird one hopefully theres a easy fix
all my heaters work feet/ side but the centre heaters dont blow hot air when its set on hot it blows cool air when the sides are blowing hot
any suggestions
Turbodave
Re: heaters
Post by Turbodave »
Pretty much standard issue, the centre air vents always seem to blow colder air than anywhere else... could be the flaps inside the heater box aren't sealing/opening or maybe that's just the way Cav's are. Yet to have one where proper warm air blows out the centre. Even Vectra's do this...
Choose Cavaliers, choose Air Max, choose Tom Wilson and Ultrasonic, choose V-power, choose 6th gear, choose Toyo Proxes, choose to prove anything is possible... except stopping the back arches rusting.
www.cavalierturbo.com www.wallaceperformance.co.uk
cunningham
Re: heaters
welcome to the site dave! :D
achwell has to be better thant the dippy that had no hot air do the airvents just pop out may have a look behind it see whats what
Cavyman_130
Re: heaters
Post by Cavyman_130 »
the centre will blow cold air most of the time, its a scape route for drawing the engine heat out in extreme conditions, but you wont feel most or any of the heat really as teh side vents take the majority of the flow, nothing to worry bout dude.
