Mud flap
Mud flap
I want to fit some rear mud flaps onto the bumper but there are no holes for the screws. Has any drilled them in themselfs or is it a no no
Re: Mud flap
It's been a while but I don't think you need to - only the fronts need any drillingchrisash86 wrote:I want to fit some rear mud flaps onto the bumper but there are no holes for the screws. Has any drilled them in themselfs or is it a no no
Re: Mud flap
How do u attach them then. Had a look there's no holes for fitting them ? I don't want to make a arse of it if there is another way of doing it
Re: Mud flap
I'm sure they just clamp around the forward lip of the rear bumper
I'm not sure what you've got there but bear in mind I'm talking about OE kit
I'll nip outside and take a look
Re: Mud flap
It's a bit murky out there and difficult to even get my fingers in for a feel with the tyres in the way but the rears appear to be held on by a couple of small g-clamp type fittings; the fitting sandwiches the lip of the rear bumper and the mudflap and the bolt tightens them together, holding the mudflap in place. Two g-clamps per side.
Re: Mud flap
There are 2 types of fitting for rear mud flaps.
Most have the clamps as you explained Colin.
However there are some which just screw into the bumper itself. My CD manual had a set when I bought it.
There is no drilling required, they should just come with some self tapping screws. All you need to do is line them up and start screwing it's that simple. Just make absolutely sure the mud flaps are lined up straight before you start.
Re: Mud flap
Cheers boys my only concern is I wanted to for Opel GM flaps off e bay but I have a spare set of genuine GM ones in the shed so I'll have a look tomorrow once home! James I sent u a pm about the v6
Re: Mud flap
Received. I was gong to get a photo for you.chrisash86 wrote:James I sent u a pm about the v6
